Version 2.0 of VCarve Wizard which is available to download now from
www.vectric.com will now allow you to machine areas wider than your tool by making multiple passes.
There are also a huge number of new features available with this release, including ...
Flat Bottom V-Carving, optionally using two tools.
Profiling outside and inside of selected vectors
Machining along selected vectors at a specified depth
Pocketing for selected vectors
Support for ball nose and engraving cutters as well as end-mills and v-bits
A tool database has been added to store tool geometry and speeds and feeds
And many more improvements ...
For a more complete list see
http://vectric.com/vcarve-download/W...w/WhatsNew.htm
As before, a trial version is available which lets import your own geometry and calculate and preview toolpaths (but not save them). You can however save toolpaths for the provided example files and cut them on your machine.
