Check this dxf out in visualmill. If you expand the "curves" item, under "geometry" you'll see that it's made of arcs and polylines.
This should give a smoother output.
BTW. The simulation of the cutting is always rougher than it actually comes out of the machine. Unless of course your machines max resolution is really low, like 1mm. |
