  #10
Old 10-05-2005, 05:30 PM
MrBean's Avatar
MrBean MrBean is offline
Gold Member
MrBean is on a distinguished road
That depends on what else you have the file saved as, other than the dxf you posted here. I've never used Coral draw and don't know what it's native editable fromat is. e.g. PhotoShop's native format is .psd
If you only have it saved as the dxf, then I'd say you need to redo it and save it with arcs.
I'll upload a similar dxf here in ~10 mins. You can load that into Vismill and see that the geometry contains arcs. Yours does not. So you need to either, resave the original file as a .dxf with arcs, or redraw the text and then save as .dxf with arcs.
