Originally Posted by swoolhead All the home made designs seem to be missing the planetry gear that slaves all the screws together. I wonder what difference this makes?
Nice work BTW!
Stephen. |
If you look closely the gears DON'T tie the screws together-directly. They mesh with a ring gear. Here is my take. The little gears can't be of a larger diameter than the threaded piece they are attached to: the main screw would never fit though. But they could be the same
or smaller diameter. If they were smaller, the ring gear would need to be resized to mesh properly. But changing the relative diameters affects he "gear ratio" between them. Thus, for a single turn of the body, you could get more or less rotation of the inner screws. If they spin faster, then the main lead screw will travel further for a given amount of nut rotation. So the ones without lose nothing-they are just operating at a "fixed" design point.
Posix, I posted earlier and said I thought this looked complicated/expensive. What you have done has changed my mind. I'm really impressed by the way you dove right in and tried it. Way to go!
Lance
