Not really a useful program Lance. It was just to let me know that I could create a DXF file. It's just a form with the ability to change a few parameters and create a single polygon that is saved to a dxf file called "vbtest.dxf". The dxf file will be in the same directory where you install the program. It's completely useless except to see the code to create a DXF file. So, since you can't see the code, it will be useless to you. Unless you want to draw a single polygon and save it as a dxf file. Here it is zipped into an install program. You must change the settings for all the parameters with the scroll bars. Typing them in won't work. After setting all the parameters where you want them, click the command button to create the file based on your settings. You'll have to use some other program to look at the file you create. Like I said, useless.
