Thread: DeskCNC
Old 09-27-2005, 07:24 PM
ger21's Avatar
ger21 ger21 is offline
Originally Posted by wmgeorge
you don't seem to need a 2 GigHZ 1 G RAM XP system to run the software or hardware. I'm a little concerned that Mach II requires the above system just to run a simple milling setup!!
A lot of people use Mach2 (and now Mach3) with 750Mhz PC's w/ 256MB RAM. With a clean install of Windows, and nothing else, that should be all you need. Although if you need the 45Khz step rate, then yes, you will need the system you mentioned.
DeskCNC will supposedly run on just about everything.
