Acculube also makes an air/lube system, which uses a regular air line lubricator as an oil source. The oil drip adjustment is a little finicky. But, come to think of it, that might be a much more economical solution for you. I'm having trouble finding a good link that will demonstrate this product for you.
You might have to acess them through a dealer like Travers Tool Co, or some local distributor of your own.
I guess the reason I went with the Trico originally was because of the handy electric solenoid on/off function.
__________________ First you get good, then you get fast. Then grouchiness sets in.
