Somehow I just knew you would reply! I like the fact that I can use a small compressor as they are dirt cheap over here, whereas the bigger 10+CFM for the vortex unit would be pricey/big/noisey. I belive you mentioned before that if I set up a nice dust-collecting shroud, this would take away the chips and mist in one hit, leaving very little residue? I know you can buy "air mufflers" to reduce the noise of the vortex tube, but they are still about 70dB of noise. I do believe I am leaning towards the trico now! Cheers Hu. One last thing, is trico the only company to supply this type of system? i have searched on Google but became bogged down with regular mist units. |
