Commands are broken down into 'Tokens'. A Token consists of an Address Label and a Value. The Token 'X2.5' begins with the Address of 'X' (in this case representing the X axis) and its value of 2.5. Tokens can begin with a space to make the output file more readable. All Tokens must be created before they can be used. To create a Token, select the Token you wish to create from the Tokens group and a variable.
Available Tokens are:
Xt for the X Position
Yt for the Y Position
Zt for the Z Position
It for the Arc Center X Position
Jt for the Arc Center Y Position
Rt for the Radius
Nt for the Line Number
Ft for the Feedrate
St for the Spindle Speed
Tt for Tool Change
Ct for tool clearance
Misct for any miscellaneous commands
Available variables are:
None
Sx for the Start Point X of a toolpath
Sy for the Start Point Y of a toolpath
Sz for the Start Point Z of a toolpath
Ex for the End Point X of a toolpath
Ey for the End Point Y of a toolpath
Ez for the End Point Z of a toolpath
Sa for the Start Angle of an Arc
Ea for the End Angle of an Arc
Rad for the Radius of an Arc
Cx for the Center X of an Arc
Cy for the Center Y of an Arc
Ix for the Incremental Center X of an Arc
Jx for the Incremental Center Y of an Arc
Cv for the Clearance Value
Nv for the Line Number Value
Tn for the Tool Number
Enter the number of decimal places for this Token and whether it needs a '+' to denote positive numbers and press the Create button. An example of the newly created Token will be displayed at the bottom.
__________________ Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com |
