So are you trying to trim formed composite components? If so, does the trimming have to be done on the cnc? Or can they be done as a 2nd. Operation using a dedicated fixture?
I'm sure you’re dealing with movement with the plywood. How much? Depends on a number of things, the number of plys, the species of wood itself, and how the tool is constructed, etc.
I've been machining tools for a local composite shop. The majorities are MDF. But we are now using high-density foam as well. We've found each material has issues unique to each. |
