Old 09-16-2005, 02:08 PM
Starwoes Starwoes is offline
Starwoes is on a distinguished road
Originally Posted by Al_The_Man
What type of Welder? Stick? or MIG?
The stick welder requires constant current source and the MIG constant voltage, you will find that the stick welder transformers have magnetic shunts the often can be cranked in and out to cause the voltage to regulate depending on weld pool resistance.
Hmmm, so it gets deeper. I'm talking about a welder where the electrode does not get consumed. I guess GTAW or something. What does constant current get you as opposed to constant voltage?
Al_The_Man, if I got this right, because the stick needs constant current, they are regulating voltage to keep current at the same set level??
