A lucky find, a good machine? | | I am so very happy! I happened upon some linear motion stuff for free! Some was even new in box!
What I have found:
-2 times 120 cm (48") IKO LWHD25 rails with 2 bearing blocks per rail. These were new in box.
-4 times 110 cm (45") NSK LGY25 rails with 2 bearings each. These are mounted 5" apart on a 1/2" thick metal plate. I have two plates with two rails each. One of the bearing blocks is missing it's balls though.
-1 times 94 cm (37") 20mm NSK2009z ballscrew with front and end bearing with a 150oz/in SloSyn stepper attached.
-1 times 123 cm (48") 20 mm NSK2009z ballscrew with front and end bearing and a huge whopping 450oz/in stepper attached.
-2 times a 55 cm (21") 15mm rail with one THK RSR15VM bearing each.
I will post pictures in a few moments. I was thinking of using one of the plates of with the 2 NSK rails with the 37" ballscrew module as a complete Y-axis. The new IKO rails with the longer ballscrew will be the X-axis. I am unsure what to do with the z-axis though.
It is highly unlikely that I will happen upon more good stuff any time soon, and building the Z-axis with crappy parts would be a waste of this lovely stuff. Can anyone help me sort out my design?
Kind regards from a very happy Tim! |
