Ready whatever type of upload/download device you have and set the output type to EIA (ASCII) select MODE SELECT switch to EDIT select address PRM input -9999 and push PUNCH button or whatever the button you have for output.
The list of parameters for 0000 to 0004 are the options and should be recorded by taking them off the Parameter screen.
They can be re-loaded by hand or by READ in. the small toggle switch on the bottom left of the main circuit board has to be in write posn. select the addrss PRM, input number -9999 via DATA key push the READ button, set read toggle switch on Mainboard back to original position.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
