Tip -
When you get above 220 grit use water to keep the paper from plugging, which can ruin your work.
After about 600 grit, I would go with a cotton buffing pad on a die grinder if your part/mold will allow it - too much aggression and you can loose/blend fine detail.
Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
