Maybe! The wheels that come with it may not be exactly what you'd want, but that is easy to fix. It is actually maybe a little underpowered for an 8 inch grinder. Depends how hard you want to lean on it. 3/4hp is more common for an 8" grinder. It would sure be nice to examine the shaft size farther up from the wheels, to see if it is as beefy as a 3/4 hp unit. Otherwise, the thing will always seem to be buzzing because of shaft flexure due to slight out of balance.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
