Old 09-05-2005, 12:54 PM
Barker806 Barker806 is offline
Barker806 is on a distinguished road
Originally Posted by ChrisJ
Brian,
I have a question for you. The programming that you have performed and offer for $50, it does not need to be specific to one's applications?
Chris
The program that I have done just slaves the PLC to mach3. The inputs and outputs are set on the port and pins page by selecting PORT 0 and The PIN of the output or input. So If I wanted to have a limit switch on input 3 I would just put Port0 Pin3 and if I sit the switch on the PLC you would see it in Mach 3 on the Limit LED.
Hope that helps.
Brian
