After more research, I'm wondering about which type of belt to use.
Is a metric HTD series better or just use a Standard H series belt. Does this make any difference? Most likely design is to use a open belt, however it will be attached to the moving table frame with clamps, one flanged pulley on each end.
Drive one pulley with the servo/stepper. Belt width of min 25mm, maybe wider? |
