Old 09-02-2005, 03:35 PM
Geof Geof is offline
You say the shaft is brass but do not identify the material of the housing for the thrust washer. If the housing is also a good conductor of heat make a thin thrust washer using UHMW or Teflon with a backup washer in brass. The shaft, backup washer and housing will act as a heatsink keeping the thrust washer from getting too hot.
