Thread: DSTV Viewer 6.0
Old 10-11-2011, 08:39 AM
ConAuto's Avatar
ConAuto ConAuto is offline
ConAuto is on a distinguished road
Update to Viewer
Controlled Automation has released an updated viewer (v.6.1) for DSTV (NC1) files.
You can find a 30 use trial version available at Link to version 6.1
The viewer does 2D and 3D viewing of DSTV files.
It will also export to our CADCAD and WinCAd formats.
The following prerequisites are required:
* Visual C++ Runtime Libraries (x86)
* Windows Installer 3.1
* .NET Framework 3.5
* .NET Framework 3.5 SP1
If these components are already installed, you can click on the launch link. Otherwise, click on the Install button to install the prerequisites and run the application.
If you have any questions, please post them here.
Thanks,
The Controlled Automation Software Department
PS - you may qualify for a free copy of this software. Do you supply a fabricator (with DSTV files) that uses Controlled Automation machines?
