IKO Linear slides - How freely should they move? | | I bought some 25mm IKO linear slides off of ebay. I unpackaged them today and tried to manually slide the carriages along the rail. They seemed quite stiff. Cleaned them up good, and it halped slightly, but I am still disappointed with them.
My question is, How freely should they slide? I was expecting to turn the rails at a slight angle (say 30 degrees) and watch the carriages slide down the rails on there own. These I can be turned vertically and they wont move.
This is my first go round with linear rails of this type. Am I expecting to much, or are these not quite up to par. I was seriously considering contacting the seller and voicing my lack of satisfaction, but I wanted to make sure I wasn't expecting to much in the first place. They were discribed in excelent condition.
Also, these bearings were greased, but the grease doesn't seem to be in the tracks of the ball bearings inside the carraiges. The inside of the ball bearings are completly dry and clean. Should the grease be completly through the entire raceway for the ball bearings? If so, what kind of grease should I use? These seemed to have a very thick type of grease on them, and I was thinking something with a little bit on the thin side viscosity.
Thanks all.
Dan
__________________ Check out what I am working on at www.routerbitz.com! |
