what should I use oil or grease to help the motion on my M16 thread rod?
also I have some little pb...the rod is little bit bended. I checked and all the bars you can buy are very little bend. If I increase tension on the rod, It seems that it does'nt t help much...
I am using Stainless steel...should I use something more soft so that the tension can make it strait? |
